Re: Do I Have a Vacuum Leak?
Posted by Ron in Nebr on April 11, 2006 at 06:50:46 from (12.192.38.28):
In Reply to: Do I Have a Vacuum Leak? posted by Kenneth Fass on April 11, 2006 at 06:33:43:
Glad you found a simple solution- that's always good!
Also glad to hear you didn't have a vacuum leak. Most are unaware that vacuum that has leaked out of older engines is building up in the upper atmosphere at an alarming rate and is enlarging the hole in the bzone layer. This "hole" doesnt really do anything but alert scientists in the northern hemisphere have noted a trend of warming in the summers and cooling in the winters they think might be linked to vacuum buildup. They think the vacuum also may be sucking up all light once a day, causing a phenomenon they've named "night"...
