Re: Correct color of 140 rims
Posted by CNKS on April 11, 2006 at 17:57:13 from (204.249.178.138):
In Reply to: Re: Correct color of 140 rims posted by Hugh MacKay on April 11, 2006 at 01:25:29:
Hugh, when someone says "rims" I automatically think of the ones that are bolted to the wheel or hub as opposed to welded. Although I suppose a one-piece wheel can be called a "rim" I consider rims detachable. In the case of the 140, only the rear rims are detachable, so that's what I was talking about. Some of the utilities have white front "wheels" but that is not an all inclusive statement. So I should have said rear rims, and those that actually have detachable front rims were always silver. Don't know if I have seen a 140 in person, not any around here I know of -- I think I knew they had one piece fronts, but that is only from pictures. I think all wheels with the rims welded on had the same color rim and wheel.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
