Re: farmhand loader on 300/400 fit H?
Posted by Ia Roy on April 11, 2006 at 19:49:25 from (69.66.77.115):
In Reply to: farmhand loader on 300/400 fit H? posted by combinekid on April 11, 2006 at 19:14:15:
I remember more than 40 years ago dad took the loader off the H and put it on the 400 because it had a better hydraulic pump and he was moving some dirt into the barn. Also the extra weight and power didn't hurt.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
