farmhand loader on 300/400 fit H?
Posted by combinekid on April 11, 2006 at 19:14:15 from (207.200.114.33):
at a local tractor dealer there is a rather dilapidated old farmall 300 or 400. I can't be sure cause all the tin is removed an there are no numbers on it. The tractor has a farmhand loader that has a pto driven hydrolic pump. The loader looks to be ok except for a few oil leaks. I was wondering if the loader would fit on my farmall H? Are farmhand loaders any good? Also approx how much are they worth? Thanks a bunch!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
