Re: farmhand loader on 300/400 fit H?
Posted by Nat 2 on April 12, 2006 at 08:24:03 from (64.80.108.52):
In Reply to: farmhand loader on 300/400 fit H? posted by combinekid on April 11, 2006 at 19:14:15:
You can tell if it's a 300 or 400 by the angle of the steering shaft up to the steering wheel. A 300 will have quite a steep angle, while a 400 will be almost flat.
The 300 and H have the same frame width, so the loader will bolt right on.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
