Re: farmall H still wont start
Posted by Brownie 45 on April 17, 2006 at 05:45:33 from (207.177.82.21):
In Reply to: farmall H still wont start posted by jdo on April 16, 2006 at 16:56:55:
Is spark getting to the plugs? If you have spark from the mag to the distributor cap & none to the plugs, check for problems in the distributor cap, rotor , & don't overlook the carbon contact & spring in the center of the inside of the cap. Otherwise, check that the rotor is "pointing at" the proper sparkplug terminal in the dist, cap when that sparkplug is about to fire.
