farmall H still wont start
Posted by jdo on April 16, 2006 at 16:56:55 from (207.200.112.163):
Had family mechanic look at carb seemed to be working fine. have a mag ignition he thinks timing is off 180 degrees is that posibble because it does not back fire when sprayed with starting fluid. should i change from mag ignition to a battery ignition. thanks for the help
