Re: M Mag troubles
Posted by Nebraska Cowman on April 22, 2006 at 14:28:12 from (65.169.97.206):
In Reply to: M Mag troubles posted by Stacey Austin on April 22, 2006 at 13:31:16:
If you are running a true magneto the wire to the condeser post on the outside is a ground wire for shut-down. I'm not sure you understand what you have. Can you post a picture?
