Re: Age of a 140?
Posted by Nat 2 on April 27, 2006 at 05:15:11 from (64.80.108.52):
In Reply to: Re: Age of a 140? posted by chadd on April 26, 2006 at 13:43:56:
You are correct.
The 140 was made from 1959 through 1976, I believe. In the beginning, it had a 460/560 style "4-bar" grille with flat front, but rounded corners on the sides. When the '06 series came out, it got a more "square" grille to match the style of the larger tractors.
