Re: Carb weep hole
Posted by River Bottom Farmer on April 30, 2006 at 06:43:45 from (205.188.116.133):
In Reply to: Carb weep hole posted by Kendog on April 30, 2006 at 05:01:51:
I would pull the fuel supply line off and open the drain and blow a little air through it may be a small piece of dirt stuck between the needle and seat not letting it close all the way.Blowing a little air through it will most of the time clear it out if this doesnt work then I would check my float level. Did you put a new needle in seat in it? This also may be your problem. Hope this helps, River Bottom Farmer
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
