Re: 6v charging system problem
Posted by Bob M on May 11, 2006 at 16:44:45 from (69.205.125.67):
In Reply to: 6v charging system problem posted by jim barlow on May 11, 2006 at 14:54:34:
Jim - Run your open circuit voltage test again only this time with the generator F terminal grounded. A good generator should give something like 18 - 20 volts (or more...) with the engine running at governed RPM.
However if you still get only a couple volts with the field grounded it most likely means there's an open circuit somewhere in the field circuit. You'll need to open the generator to figure out where.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
