Re: M won't start without starter fluid ? WHY??
Posted by the tractor vet on May 15, 2006 at 10:12:27 from (66.202.111.132):
In Reply to: M won't start without starter fluid ? WHY?? posted by Sam F. on May 15, 2006 at 09:34:27:
Well since i cna not check it out myself , the onlything that comes to mind here is the this tractor just does not know how to SUCK . Or your not holden your mouth just wright while tryen to start it . Now it could be that it is low on compression there for it is not sucking hard enough or there is a manifold leak or the choke is not closing off all the way . Pull the intake hose off and put your hand over the carb and crank it and see if it will suck the gas up that way and start . With the age of the tractor and over the years who knows waht has been done to it you darn near have to start at square one and go from there.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
