Re: M won't start without starter fluid ? WHY??
Posted by Sam F. on May 15, 2006 at 10:44:19 from (64.113.111.97):
In Reply to: Re: M won't start without starter fluid ? WHY?? posted by the tractor vet on May 15, 2006 at 10:12:27:
Carb hose is off and it seems to suck my hand real hard ?? The second you squirt the starter fluid in it starts right up and runs and sounds real powerful. Will run perfect, doesn't act like it's starving for fuel or anything. Runs perfect. It has me baffled as good as it runs ???? Going to do a compression test this weekend and see what it comes up. What should they be ??
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
