M axle housings
Posted by Paul G. in Mn on May 15, 2006 at 16:46:50 from (206.183.179.106):
I am wondering how hard of a job it is to change out rear axle housings on am M. Ive got a 1939 and need to change out the main transmition houseing due to being chacked and haveing the wrong lower shaft in it. I am going to put one in from a 1940 I have but would like to keep casting codes right. I cant find a casting code on and main transmistion houseing but can on axle houseings. can I just remove the wheel and unblot the housing and just slide it off or do i need to remove it from the bullgear? thanks Paul
