Re: '40 H transmission
Posted by Shovelman on May 16, 2006 at 05:21:54 from (68.191.57.27):
In Reply to: '40 H transmission posted by RD/oh on May 15, 2006 at 16:38:13:
The input bearing housing/shaft assy can be removed without splitting the tractor or pulling the top cover, but it is tight, especially if the tractor has a belly pump. Before you start, check the bearing play in the input shaft. Also, check for oil leakage at the brake housings. If there is, remove the covers and check the brake drum bearings for looseness. If there is, take the time to pull the top cover and check everything out. There is a small roller bearing mounted on the end of the pinion shaft which rides on the inside of the input shaft/gear. It is caged, but when it gets worn the rollers will fall into the trans. case when you remove the input shaft, requiring you to pull the top cover off and fish out the pieces anyway. The pinion shaft ball bearing sometimes requires replacement, and the top cover has to be off to do it. Note: If you have to pull the bearing housings located behind the brake drums, be sure remove the bull gears BEFORE pulling the bearing housings. You will break the bearing housings if you don't pull the bull gears first. Splitting the tractor is not that bad. It can be done in less than an hour. We just went through the transmissions on both of our H tractors, so if you need bearing or seal numbers, etc., let me know. Good luck, Scott Check our website:
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
