Re: Super A Sickle Mower Help (pictures)
Posted by Jim Becker on May 21, 2006 at 10:38:09 from (71.96.7.230):
In Reply to: Re: Super A Sickle Mower Help (pictures) posted by Hugh MacKay on May 20, 2006 at 03:12:13:
Hugh,
As you pointed out in another post of this thread, much of the mower is the same regardless of the exact model. Someone with a manual for any one of them would be able to do nearly any required maintenance and adjustments. The differences between an A-16 and A-21 that I can see in the pictures are:
1) Hydraulic lift parts (lifting crank, lifting arm etc.) in place of the hand lift parts.
2) Single lifting spring rather than double.
3) Bolted tilting bracket at hinge rather than hand wheel.
4) Quick attach drawbar with attaching cam and one diagonal brace rather than 2.
Likewise, I don't think it is the heaver A-24 mower because of the single lifting spring and single drawbar brace.
