Re: Farmall H, top cover off tranny, now what
Posted by captaink on May 23, 2006 at 06:37:16 from (66.115.214.56):
In Reply to: Farmall H, top cover off tranny, now what posted by arod on May 22, 2006 at 22:35:41:
It is hard to say where to stop on these old tractors, but I would check the bull pinion bearings and seals while you have the cover off; especially if you take the bull gears and axles out. If the inside bull pinion bearing needs replacement, the bull gears have to come out to get the carrier out to replace the bearing. This is done much easier with the cover off. As cowman said the only roller bearing I can think of is on the front of the top transmission shaft. You can’t see it unless you pull the input shaft (thus cowman’s suggestion about wiggling up and down) and housing out of the top of the case. If you have to replace it a rubber band around it helps keep the rollers in place during assembly. If you really want to be though, check all the bearings and replace all the seals. They are not cheap these days, but neither is the gear oil that you will be putting back in it. Good luck
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
