Re: 656 carburetor
Posted by Don, Ohio on May 26, 2006 at 13:53:53 from (71.72.140.9):
In Reply to: Re: 656 carburetor posted by the tractor vet on May 26, 2006 at 07:20:44:
Thanks for the advice! I think I will leave it alone, because so far there isn't any gas on the floor, just a few drops hanging on to the bottom of the carb.
I don't know if you remember, but you responded to my hydraulic problem on this tractor earlier this year where I had lost all the hydraulics. The problem was that the hub had sheared off the pressure plate just like you said. So, thanks again! Your advice was very helpful! I have another question, though, is the hub shearing off a common problem? Could there be something else wrong that would have caused those rivets to shear or is it just normal wear and tear? I have put about 40 hours on the tractor since replacing the pressure plate and so far everything works fine.
