Re: 6 Volt Regulator on Farmall A
Posted by MACE on May 26, 2006 at 17:57:55 from (66.23.230.57):
In Reply to: Re: 6 Volt Regulator on Farmall A posted by John T on May 26, 2006 at 17:27:46:
John,
I measured the voltage on the load terminal. It showed 6 volts like you said. I then measured the resistance from the load wire to ground. It showed 4.2 ohms. When I connect the load wire to the resister on the bottom of the switch, I see the 2 amp load on the amp guage. I am assuming I have it wired correctly. I do not have a wiring diagram that shows where to connect a load wire to a switch. The operators manual shows that the field wire is to be connected to the resister on the bottom of the switch. Am I right?
MACE
Today's Featured Article - A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y ... [Read Article]
Latest Ad: 1979 I-H 140 tractor with cultivators.Starts and runs good. Asking 5750.. CALL RON AT 502-319-1952 [More Ads]
