Re: 6 Volt Regulator on Farmall A
Posted by John T on May 27, 2006 at 06:06:22 from (66.244.90.5):
In Reply to: Re: 6 Volt Regulator on Farmall A posted by MACE on May 26, 2006 at 17:57:55:
Mace, I fear you are comparing apples to oranges here based on different charging systems. On some older Farmalls (not sure about your tractor????) they didnt use any Voltage Regulator, only a simple 2 wire Cutout Relay. On those the gennys Field terminal wired up to the light switch which had a resistor and the field was dead grounded for high charge but grounded via that resistor for low charge. When one replaced the Cutout Relay with a VR, then the gennys Field wired to the FLD terminal on the VR, NOT up to any switch or switch resistor. The switch resistor you mentioned may be a resistor used for light dimming or the field control resistor I referred to above, but REGARDLESS THATS NOT WHERE THE VR'S LOAD TERMINAL SHOULD BE WIRED. The VR's LOAD terminal ought to be wired to the BAT input terminal on a switch, the terminal that is the main voltage INPUT. Then the switch switches that voltage to lights or ignition etc when turned oN. I still am not convinced the VR is bad, I think youre NOT wiring the right circuit(s) to the VR;s L terminal. NO WIRE connected to it ought to cause any continuous current draw cuz it will run the battery down. If the L terminal feeds a switches BAT input supply terminal, then theres ONLY current draw when the lights or ignition are switched ON as it should be. Maybe Bob M's wiring diagrams may help you?? but rememember its still possible to rewire that tractor (regardless if it originally had a cutout relay or a 3 or 4 wire VR) with your new 4 terminal VR and make it work fine. AGAIN use the 4 wire VR's LOAD terminal to feed the BAT input terminal on a switch NOT ANY SWITCH RESISTOR OR TERMINAL THAT ALWAYS CAUSES A CURRENT DRAW or the battery will run down. On 3 pole VR's or Cutout Relay systems the BAT input terminal on switches was fed off the ammeters load side terminal (same terminal that wired to BAT on a VR or Cutout Relay) John T
Home
| Forums
Today's Featured Article -
A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
