Re: 6 Volt Regulator on Farmall A
Posted by MACE on May 27, 2006 at 12:20:53 from (66.23.230.57):
In Reply to: 6 Volt Regulator on Farmall A posted by MACE on May 26, 2006 at 17:05:03:
John,
Thanks for your help so far. I think I may have found the problem. 1st, I have a jumper that goes from the amp meter to the bat input (fuse) side of the switch. I don't think it should be there. 2nd. I am going to put that load wire on the bat input side of the switch to see what a difference that can make. I believe you may have just figured out what the problem is.
Thank you,
MACE
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
