Re: SAV front axel pivot
Posted by gene bender on May 31, 2006 at 04:21:41 from (66.43.221.211):
In Reply to: SAV front axel pivot posted by RedJohn 2 on May 30, 2006 at 19:26:41:
Did you make a new shaft? The shaft is not a press fit. If you did make a new one with bushings in the axle the shaft needs to be a slip fit where the bushings seat and where it clamps on each end. The shaft should have 30thous clearence between those journals you should be able to get the measurements off the old one. Mite need to drive a could chisel between the ears on each end to get some clearence when installing. Has the pivot been welded or repaired where it is welded to the axle?
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
