Re: M burning points
Posted by Bob M on May 31, 2006 at 05:42:33 from (151.190.254.108):
In Reply to: M burning points posted by Wicksfield on May 31, 2006 at 05:23:28:
That’s a puzzler – especially after you made the switch to the “12 volt” coil! A few things however to check: 1 – (Long shot...) Are you certain the condensers are good? Use the ohms function on a VOM or DVM and measure the resistance between the pigtail and the can: On a good condenser when the test leads make contact the meter will show very low resistance. Resistance will then rise over a period of several seconds into the megohm range. 2 – Is the condenser can solidly grounded to the breaker plate? (A poor or no ground here gives a weak spark and will burn points quickly.) 3 – When the engine stopped and the ignition on, measure the current in the coil primary. You should see 2 - 3 amps or. A reading of 5 amps or more means the resistance of the ballast resistor is wrong (too low). Burned points and an overheated coil can be the result.
Home
| Forums
Today's Featured Article -
Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
