Re: M burning points
Posted by John T on May 31, 2006 at 06:22:24 from (66.244.90.5):
In Reply to: M burning points posted by Wicksfield on May 31, 2006 at 05:23:28:
Wicks, Im kinda thinkin along the same lines as Bob, heres some thoughts: Premature points burn up is often caused from excess current (around 4 amps or so should be the max) or a bad or not grounded condensor. You may need to check the primary resistance of that new "12 volt coil" as measured between its lil + and - terminals as it should be around 2.5 to 3.5 ohms or so such that the current is in that 4 amps range. The reason I say that is cuz some so called 12 volt coils are actually "12 volts" others "12 volts for use with an external ballast resistor" and some "12 volts NO external ballast required" YOU NEED ONE LABELED (or designed) 12 VOLTS NO EXTERNAL BALLAST. If your coil is one of those "12 volts for use with an external ballast" its in reality a 6 volt coil (primary resistance around 1.2 to 1.5 ohms) and your points are switching excess current and will burn up prematurely plus run hot. Some automotive 12 volt coils are lower primary resistance then the 3 ohms or so required for many points type ignitions, so to be safe, you need to measure your coils primary resistance and you need at least 2.5 preferably 3 ohms to protect the points as designed for. If you can barely hold your hand on the coil cuz its so hot it may be a 6 volt (12 for use with external ballast)coil!!!! Its hard to really test a condensor with an ohmmeter, you need a real condensor tester. An ohmmeter can tell if its bad/shorted and capacitance to some degree, but if in doubt have it tested or get a new one. Make sure its connected good to the points terminal and has a good case ground also. The points need to close nice n even n flush with each other or they burn up quicker. Let us know John T
Home
| Forums
Today's Featured Article -
Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
