Re: SA Coil
Posted by Bob M on June 02, 2006 at 12:54:54 from (151.190.254.108):
In Reply to: SA Coil posted by Steve Santini on June 02, 2006 at 11:23:36:
Steve - I read through the thread below. A couple thoughts...
You CERTAIN your SA is on 6 volts? The only way I know a coil can overheat is when a 6 volt coil is used on a 12 volt system without a ballast resistor in series.
Unless there's a partial short or something inside the coil it's virtually impossible to overheat a 6 volt coil on 6 volts!
Before you begin diagnosing the engine "woofing", dark exhaust, etc. install a fresh set of plugs! The soot on the plugs in there now now will cause all manner of misfiring and other odd behavior. Suggest also replacing them with the hotter Champion D-21 - or the AC or Autolite equivalents. (The D-16 would be OK if the tractor is in good tune and is worked hard. But when the engine is only lightly loaded - and with the lousy quality gas we get now - the D-16 has a tendency to carbon foul very quickly.)
Good luck and keep us posted!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
