Re: IH 1066 Reverse and Parking Brake Problem
Posted by the tractor vet on June 05, 2006 at 09:03:56 from (66.202.111.70):
In Reply to: IH 1066 Reverse and Parking Brake Problem posted by Mitchell Dabbs on June 05, 2006 at 08:44:13:
Well to start with i would say that ya need to work on the shift linkage from the shifter all the way down to the range transmission cover and repair replace any woren parts . If this does not fix the problem then one must go deeper in . The rev. shifter and gear can be checked by removing the side cover on the rearend behind the left steep , if the trans mission oil level is where it should be and not over full then when you remove the cliped coner cover you will only lose about a gallon and a half of Hyd oil . Sometimes on of the ends on the shifter fork breaks off and this will allow it not to stay in gear. Also if ya have to remove the range transmission cove this cover must come off also . As for the park lock if it is the old style of over center NOW is the time to upgrade to a spring loaded park lock , kits can bought from Case I H .
