Re: oddball h
Posted by Steven@AZ on June 05, 2006 at 17:55:16 from (24.121.48.188):
In Reply to: Re: oddball h posted by scotc on June 05, 2006 at 17:49:13:
There were adjustments to make on the manifold to heat up the intake side to burn the kero/distillate.
No changes need to be made to run on gasoline. I'm sure the manifold is already set for it. Or if you are concerned, buy a new manifold.
Gas won't hurt it at all.
