Re: Still having charging problems
Posted by Bob M on June 06, 2006 at 13:53:04 from (151.190.254.108):
In Reply to: Still having charging problems posted by Formerly PaMike on June 06, 2006 at 09:35:09:
3 ohms between the reg base and ground is not right! It should be 0.0 ohms.
Try running a jumper wire between the reg base and the grounded battery post, then run the engine again. I'll bet you'll find the generator now charges just fine.
