Re: Broken inner rim on my H
Posted by RMO/MN on June 10, 2006 at 07:19:03 from (64.122.139.56):
In Reply to: Re: Broken inner rim on my H posted by Janicholson on June 10, 2006 at 06:28:02:
Hello Jim,
The part of the wheel I'm talking about is the inner wheel which is cast maybe the proper name would be the hub.
Bob
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
