Re: Broken inner rim on my H
Posted by Janicholson on June 10, 2006 at 06:28:02 from (66.173.50.88):
In Reply to: Broken inner rim on my H posted by RMO/MN on June 09, 2006 at 20:10:03:
If the rim is not too rusted out, prepping and welding the break is certainly possible. There is probably a welding school close to you that would assist in putting it in operation. Make sure there is enough material to get good penetration, and then it can be smoothed off to be less recognizable as a weld, Leave no snags on the inside to pierce the tube.
JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
