Re: C fenders on H
Posted by Rexalot on June 11, 2006 at 11:39:42 from (205.245.254.146):
In Reply to: Re: C fenders on H posted by Nat 2 on June 10, 2006 at 20:39:17:
While the "fan" portion seems the same the mount and way they mount are different. The H/M has a flat mount with four bolts. These match up to holes in the axle to move the fender in or out. The C is octagonal with a corresponding U-bolt to fit the axle. Loosening the U-bolt and sliding on the axle housing adust.
I might be wrong, but from what I remember of my H, that fender would only fit on it or an M. It was all one piece. I'm not saying that you couldn't adapt the C fender to work by fabricating some type of bracket or cutting it and making the flange that bolts onto the axle and welding.
I would just look for a pair that came off an H or M.
