Re: Broken inner rim on my H
Posted by Randy as in Randy-IA on June 11, 2006 at 13:10:48 from (207.177.83.238):
In Reply to: Broken inner rim on my H posted by RMO/MN on June 09, 2006 at 20:10:03:
Hi Where in Mn are you ? I know a salvage yard about 40 miles from me that has those hubs just scattered all over the ground . Price would be reasonable and they ship too . Otherwise , maybe try ebay because some of those tractor jockey's part out perfectly running tractors just so they can make a couple dollars more off them . But that's a different whine with my beef ! Good luck ! ...Randy
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
