Broken inner rim on my H
Posted by RMO/MN on June 09, 2006 at 20:10:03 from (64.122.139.56):
The inner rim on the front of my H is broken out at one of the mounting bolts. can these be repaired or do I need to start looking for a new rim. If I have to locate a new rim any ideas I'm in southern MN
Bob
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
