Re: allan ne, 666 hydro repair
Posted by Allan In NE on June 12, 2006 at 06:01:38 from (148.78.243.25):
In Reply to: Re: allan ne, 666 hydro repair posted by Allan In NE on June 10, 2006 at 08:48:00:
Should have added:
Then, if you do get good drive in one direction, you can then "reverse" those check valves to see if the "good drive" changes directions.
If so, you know that the check valves are indeed the problem and you end up only having to buy $500 worth of parts rather than a $5000 repair at a shop.
Allan
