Re: allan ne, 666 hydro repair
Posted by Allan In NE on June 10, 2006 at 08:48:00 from (148.78.243.24):
In Reply to: allan ne, 666 hydro repair posted by maplehillfrm,pat on June 10, 2006 at 07:31:43:
Mornin' Pat, Here's what I would do. Pull that bottom cover taking note of any debris you find. Be careful, it is heavy! If you find lots of steel and brass shavings, I'd forget the whole deal, 'cause somebody tried to start it by towing. If, on the other hand, it is "relatively" clean, continue on: At this point, and by the rules, you need a pressure test and it is where we start spending money, so don't hollar at me if this doesn't work, okay? :>) However, you've already said that at one point or another, the tractor has moved 200 feet in one direction, 35 feet in the other direction and then with subsequent attempts (and the hotter the tractor gets), the darned thing "acts like it is slipping" and just won't move? Right? I'll bet you by everything that is holy that the check valves in the center section are bad. It is what hydros do; they beat the crap out of those valves and you cannot tell they are bad by just "lookin' at 'em". They are the two little guys on the upper right in the last picture. First, forget that "shift linkage" affair. That isn't the problem. It is supposed to be really sloppy and floppy like that. Pull the pump on the right hand side of the tractor also. If you are real careful and some idiot hasn't been in there with gasket sealer, you can save those gaskets/o-rings. I had mine apart four or five times and never bought a gasket. :>) Towards the rear of the openings on both sides of the tractor, you will see the center section, which contains all the valves and the steel tubing going to those valves. The check valves are on the top, the pressure regulators are on the bottom. Now, forward motion is controled by the top check valve on the right side of the tractor and the bottom regulator valve on the left side of the tractor. Reverse is handled by the other two valves: upper check on the left and lower regulator on the right. The check valves are held in place by a plug. Unscrew that large plug, then take a 1/2" bolt with standard thread and screw it into the check valve. Then just pull the thing outta there. Here's the bad part and where I can't be held responsible: My gut wants to tell you to just replace all the check valves and all the regulator valves. However, the check valves cost $240 apiece and the regulators are something like $250 a pop. So, you can see we're dumping a thousand dollars on it by using the blanket approach. So, what I would do if it were my tractor, if I had the patience and the time, is to buy just one check valve and replace it. Throw it all back together, fill it up with oil and give her a try. I'll just bet my wife's pet pig that you'll have drive in that one direction. :>) Good Luck, Allan
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
