Farmall A 6 volt charging question
Posted by G Lee on June 13, 2006 at 15:56:59 from (71.147.18.192):
I have a 1941 Farmall A with a 6 volt generator and a coil/distributor ignition system. I am using a 4 terminal regulator mounted on the generator. I am not getting a charge on the amp meter when I run the tractor. I have wired the tractor as follows: 1) Field on gen to F on reg 2) Amature on gen to Gen on reg 3)Bat on reg to positive terminal (discharge side on face) on the amp meter 4)L from reg to ignition switch 5)Wire from starter to negative (charge side on face) of the amp meter When I pull the ignition switch the amp meter reads 5 amps on the discharge side. When I start the tractor, the meter reads about 3 on the discharge side of the meter. Idle speed does not make a difference. I would think I should see a reading of charge on the meter. I have a new coil, points and condensor. The regulator is new. I have no lights installed on the tractor and I have not wired anything to the light switch. I was told by the shop the generator is ok. Do I have a generator problem? Appreciate any help. Thanks in advance. Gerald.
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
