Re: 856D starter/solenoid/click,click
Posted by Hugh MacKay on June 15, 2006 at 18:20:21 from (209.226.106.25):
In Reply to: 856D starter/solenoid/click,click posted by SDE on June 15, 2006 at 17:40:03:
SDE: What you need is a new solinoid, however you might try a trick I use to do with 560, 656 and 1066. Take the solinoid off. Under that plastic cap is a brass washer that makes actual contact to starter. Clean that washer up with sandpaper. It may not work, may last a week and could last 5 years. Be careful when you remove the cap as small wires are attached to terminals. It's best to take nuts off those, push them out, so they can stay with solinoid.
While you have it apart you can also turn the two large terminals in the cap so you get better contact.
