Re: oil in M belly pump
Posted by RustyFarmall on June 18, 2006 at 09:37:58 from (199.120.81.193):
In Reply to: oil in M belly pump posted by DK in WI on June 18, 2006 at 09:18:11:
Are you using the hydraulics to run anything else at the same time that would cause the oil to overheat? If not then it is time to rebuild that pump. A different weight or type of oil will not help. The pump holds 6 quarts.
