Re: Cub ground
Posted by John T on June 22, 2006 at 07:01:16 from (66.244.90.5):
In Reply to: Re: Cub ground posted by souNdguy on June 22, 2006 at 06:15:51:
Good point about the plugs, its easier to emit electrons from a hotter (plugs electrode tip) surface to a relatively cooler one (plugs ground strap) similar to how in a vacuum tube a heater is used to warm up the surface to emit electrons up to the unheated Plate. Ive read or heard a coils firing voltage may have to ramp up a few thousand volts higher if its wired in reverse then when wired corectly, which explains how they still run if wired backwards but NOT as efficent and maybe a tad warmer.
John T (long retired EE so a tad on the rusty side lol)
