Re: Farmall M Water Pump
Posted by Haas on June 25, 2006 at 18:29:48 from (12.65.36.177):
In Reply to: Farmall M Water Pump posted by sven on June 25, 2006 at 08:46:22:
Kirk has it correct. The bearings in the water pump can be replaced without removing the pump from the tractor. You do however have to remove the radiator to get at things. It's not a bad job once the radiator is off. If you decide to replace the bearings, do the grease seals at the same time and get a couple rings of packing to add to the packing around the pump shaft. The zerk that greases the pump shaft won't take much grease. If you overgrease the one that greases the bearings, you may push the seals out. So...don't force things.
