Re: 1971 IHC 454 Gas, 38 hp, loader, hydraulic que
Posted by PUTTER on June 29, 2006 at 05:19:06 from (69.179.203.203):
In Reply to: 1971 IHC 454 Gas, 38 hp, loader, hydraulic questio posted by Terry Hensley on June 28, 2006 at 20:08:23:
Terry You should use hy tran fluid or an equivelent oil to fill the system. I guess i'd try that first but it sounds like you have some wear issues. You might find someone local who has the equipment to test the output of your pump. GOOD LUCK PUTTER
