Re: Delco Remy distributor on a 1942 H
Posted by Wayne Swenson on June 29, 2006 at 11:38:37 from (66.228.250.33):
In Reply to: Re: Delco Remy distributor on a 1942 H posted by El Toro on June 29, 2006 at 11:03:37:
Boy, that must be the FIRST tractor off anybody"s assembly line if it was made in 1095!!
The upright Delco distributor was necessary if a live hydraulic pump was added to allow for clearance between distributor cap & oil filter.
