Re: Delco Remy distributor on a 1942 H
Posted by El Toro on June 29, 2006 at 11:03:37 from (64.12.116.65):
In Reply to: Re: Delco Remy distributor on a 1942 H posted by RustyFarmall on June 29, 2006 at 06:13:05:
Hi Rusty, We had a new Farmall H in 1095 that had a mag. There were problems with starting it and it was converted to battery ignition with a distributor. That seems to be a somewhat weird since we had a 10-20 with a mag and I don't remember ever having a starting problem with it.
Even in cold weather it would start since we would spread manure if the ground was frozen and we used wood in an old cook stove and we used it for sawing wood. We got a C later that year and it always started. Hal
