Re: H oil filter seal. Use it or not?
Posted by Skip on July 03, 2006 at 08:54:32 from (68.176.108.159):
In Reply to: H oil filter seal. Use it or not? posted by Elk Farmer on July 03, 2006 at 08:44:56:
An interesting question. I've always used the seal although it's not easy to get the thing to set square in the groove when screwing the cover back on and for that reason it usually seeps a small amount of oil but if you don't use the seal it leaks like a sieve.
Replies from some of the other "H" owners would prove very interesting! Somebody with more expertise probably has a solution.
