H oil filter seal. Use it or not?
Posted by Elk Farmer on July 03, 2006 at 08:44:56 from (64.12.116.65):
When changing the oil filter on a 1940 H do you use the rubber "O" ring seal or not?
It seems that if I put the seal in the grove in the base the outside canister does not fit all the way down. If I leave the seal out the outside canister seems to set more firm in the base.
Thanks
Carl from Michigan
