CHAD S OR OTHER MOTOR GURU HELP
Posted by MAGMAN on July 03, 2006 at 10:11:49 from (67.142.130.25):
HI CHAD OR SOMEONE ELSE.
I have this H I built last year for stock pulling, I just checked the compression and I have 140# in all cyl dry and 150# wet. But I dont have much power?
It has 3 and 7/16 high domes, Head milled about 60 to 75 thousands,169 cam shaft 300 manifold and SM carb, I rebuilt the Govener my self just to make everything tight.
OK as you all can probly tell I am running a high output H4 mag on her. 35 degree trip and timed at TDC, Any Ideas? And no I dont have a dist for her lol
JON
