Re: H, transmission gear replacement... 1/2 way t
Posted by MAGMAN on July 03, 2006 at 10:18:20 from (67.142.130.25):
In Reply to: H, transmission gear replacement... 1/2 way there posted by arod on July 03, 2006 at 10:12:13:
as I remember you need to take the bolts out where it goes through into the rear housing. Watch for # of shimms gaskets and then she should pull back and then out and dont forget to check that front roller bearing there only about $25.00 and oil it good when you reinsatll.
JON
Its been about 7 or8 years so I may have forgotten things.
