Re: H oil filter seal. Use it or not?
Posted by Randy in NE on July 03, 2006 at 11:52:44 from (204.124.192.90):
In Reply to: H oil filter seal. Use it or not? posted by Elk Farmer on July 03, 2006 at 08:44:56:
The best thing would be to take the time and dig the old seal out. If if is so hard that you have trouble getting it out then it is probably tooooo hard to do a good job of sealing. It is a square o-ring and an ice pick or an o-ring tool should dig it right out.
