Re: smta hitch
Posted by Hayfarmer on July 03, 2006 at 18:10:46 from (66.243.249.91):
In Reply to: Re: smta hitch posted by Aces on July 03, 2006 at 13:04:40:
Thanks for the replies. Had a bolt that holds the roller break and drop the baler hitch to the ground, jammed up the pto but luckyly didn't break anything. Started thinking about the sort of triangular shaped plates I had seen for this.
