Re: smta hitch
Posted by Nat 2 on July 04, 2006 at 05:29:52 from (24.93.8.168):
In Reply to: Re: smta hitch posted by Hayfarmer on July 03, 2006 at 18:10:46:
One problem with that, though...
The axle housings were not designed to be the primary pull points on the tractor. It'll be okay if you're just tugging around a little baler and dropping bales on the ground, but if you're hauling loaded wagons up and down hills, you're likely to rip the axles right off the tractor!
Best to fix the oblong hole in the drawbar up front... Someone with a welder can do that easily.
If you go the plate route, make sure you get the distance right from the end of the PTO to the center of the drawbar hole. Otherwise, you end up with knocking knuckles.
